Does anyone have any input as to the best oil cooler kit for the 1990 m30b35 engine? (fitted to e9)
Would the m6 setup, or the e12 m535i setup work?
Would the issue mentioned below by another member be a problem?
"""on your oil pressure issue, I just learned that there are three different gaskets that were used where the oil filter housing meets the block. You can see them in the attached image. Some of the later 3.5 blocks have a passage back to the crankcase for a pressure relief valve in the housing. The only way to tell is by looking at the block itself. If someone used the wrong gasket, you end up with an internal oil leak. Also, if you use the early style housing on a later block you need to plug the passage or it never develops full oil pressure. Carl Nelson at La Jolla Independent was explaining this to me yesterday and has the plug if you end up needing it. Mine ended up being the older style (my block is an '85), but I was happy to learn about the differences for future reference. """
Thx Mike
Thx Mike
