Hans
New Member
My daily driver is a 2800CS that I've had for about 3 years. The PO told me that the engine was rebuilt in '91 -- about 100,000 miles ago. Since I bought the car, the oil pressure light has always gone out about 2 seconds after the engine starts (which, if the car's been sitting for a day or so, happens only after the engine cranks long enough to get some fuel into the Webers).
Yesterday, the oil light flickered on while the car was idling hot, stuck in traffic. As I headed home, the threshold for oil-light-on rose from 1000 rpm to as high as 2000 rpm when the temp was hot and to 1600 rpm when the temp was cooler. I checked the oil level several times and it was always OK.
Is this an oil pump problem? Relief valve? Or???
Suggestions appreciated.
Hans
Hans
