I have a symptom that I have had trouble resolving and hoped to find some help from the experts here. The issue is, since completing my 3.5 installation, on cold start it takes about 6 to 8 seconds for the oil pressure light to go out. This is after the car has sat for several days. Some background:
I am using an M30b35 from a 1990 seven series. Using the excellent advice and documentation on this forum, I retained the B35 oil pump but attached the E9 M30 pickup and used the E9 pan. I have the L jet intake system with E21 intake runners and a Tii brake booster. With this arrangement I couldn't use the upright oil filter housing from the B35 because of interference with the brake master cylinder. So, I opted to use the B34 filter housing and cannister. I made sure to plug the hole in the block that isn't used and must be blocked with this arrangement.
My question is, does this sound like a typical situation given my combination of parts? I did some internet research and found one thread that suggested this delay in the light going out is not unusual for M30s that have the pressure switch at the back of the head. There was also some reference to failed check valves but I couldn't find consensus in that regard.
I did connect a mechanical oil pressure gauge and once oil pressure is established all indications seem normal. 55 psi cold, 18-20 at idle hot. I appreciate any thoughts.
