Oil Service Sticker
HB Chris
Huntington Beach, CA
The oil stickers are the ones most usually wrong. Here is Chuck's original 73, should be same as 72 and 74, I don't have any others. Note the 6000km, there are others which are not correct.
I believe size is 126mm wide and 98mm tall.
Please post a pic and/or confirm size.
Thanks Chris,
I have this file ready to go but you are right, there are other types including 3000KM and 7500KM which are not correct. Those are for 2002 and 2002 turbo only.
Oil sticker is approx 118mm width x 107mm height. Possible 1mm shrinkage from age/heat. June 1972 build date.
orM8ijHV6x2xkVknPRrMjKkiy4OfIllM1Jq6b3RuWGyklVYmtNWki664RAlZAt8OiR6jyJodoOLmNqbxQIdCxZqu7Imyh1tNdmwjXWofCoUd67extrpwexRfR9T9XPcusrPclMn4mZffq0DxQBfjstpllVDRMGYuzy7_KllQrt9UqOKbvzuYH-Q1x0uhTbkZgJ9VSO8X-OcahhVnNrFIXKCUWBmfg7Y3N3ukIm-2Equ_d0roT3qejXGVzA3pxDZg8RJgQnXoelmO3VFpjt17aGjO9PYHnVQm91AifI6tv9R86uH67kiS0vpH-rQLj7dbQP4xjnKIjId0mIzyKu_JhWVRPqdrHzUhISkleoO3a2ktoYkzYVZtmIrAz2JAyHpXyUprBevgZjDH3r7eV3-g7LQeqj2V1ju4qE6cXBe8v0ME4VU5NiihChMa3GDDONgdV-YTZwkkFRu3ZYHkc1_ePLNz-hEdO596RdmMK3o_2VynvC0Q_ryFqYAlHZL8AxgA33jWN1rLCowsF5H_sOlzliV7BE2sjnir1E05PxwO5r2vn8IwYgolRrb1JKf1aVH4QoSK1HUdUbsPVWm0AUX5nrwBFRvDAC6eH3bvX3gnfQcZuK62iliEldLouA9t5J4kCmQBXPsDt_WdPTSa5XGMN8Rr=w1036-h777-no
  • Like
Reactions: m73
And now I’m wondering if Chuck’s is a repro, it’s very different. Anyone have an original 73 Oil Service Sticker?
Yours is same as 70 2800 and 70/71 2800CS.
Thanks Steve, all your original decal pictures are more than appreciated :)
I would post on each thread but I 'hope' one thank you is enough......
Applaud your efforts,
Mo
It looks like it was placed over something that left residue behind.
I have no absolute knowledge of the car before I got it, but most of the stickers and other wear items like seals all look like they have shrunk back a mm or so. It sure would be strange for the original owner to replace the stickers at 19k miles before putting in a container. The engine bay was dusty when I got it and under hood insulation definitely original. Would turn to dust if I touched it. So that’s all I replaced.
Original 73’, just took it.
