After reading lots of posts on the cooling fan subject, I realize that there are a lot of upgrade options. I still have not decided which way to go. In part because I will be doing the M30B35 upgrade at some point so I am not too keen on spending too much effort and/or money upgrading the original cooling system.
So, just to get me through the upcoming summer months, and since my temp needle goes with alarming frequency to just below the red before the fan finally gets to work, I wanted to do a simple temporary fix which some people have mentioned on here. It involved "using longer bolts so the fan is always on". I imagine this is a way to lock the clutch out of the equation. Unfortunately I did not see any specific info on it such as which bolt to lengthen and which ones to use instead.
Would anyone have any info they would be kind enough to share?
Thank you
Bo
Thank you
Bo
