For sale wiper system components.
75 euro for the bunch.
1 long connection rod. Fresh glass bead blasted and bright zinced with two plastic bushings (protected during glass bead blasting). It has a deep scratch from rubbing on something (see pics, was still functional on my car)
Spindle with 1 ball joint, good condition, only very slight wear. Glass bead blasted (ball joint and axle protected) & re-zinced +
Threaded sleeve, yellow zinced.
+ set of small plastic rings and splined cap (nice splines still)
+ set of aluminium rings and large nuts for mounting through the body.
Spindle with the 2 ball joints is basically the same, but the pin and inside of the the threaded sleeve has severe rust pits and is quite worn; they have about 1mm of play. I never noticed it during driving in the rain, it is functional' but it would surely benefit from a new pin and internal bushing/re-sleeve. (Not easy, requires a machine shop).
Located in NL, shipping worldwide.
