Part's questions?
m5bb
Peachtree Corners, GA
Have new WWasher pump and system is working (pumping) but no water from nozzles?
Removed white 90 degree device from where nozzle goes through hood.
Nozzles are ok with this device removed.
What is this device and what does it do? (one way valve?)
is it necessary to have.
Didn't see on parts list?
Are trunk lights unobtanium since they all have melted?
Thanks,
Gary
Gary,
my understanding is that its the same light under the hood thats in the trunk. 63311362711 ($43.87 from Penske - $27 on realoem) the base is NLA. this lamp is used on a lot of BMW - e3, e9, e12, e21, e23, e24
cheers
scott
Thanks Scott.
I looked at that but could not tell if lights were same part number.
The other item that is attached to the nozzle is shown as a valve.
61661355299 $16 ea list.
I think they are one way valves to keep the fluid from draining back to the tank.
I think the washer fluid has corroded mine and they won't work.
Going to soak them in ? see if I can loosen them up.
They were used on a bunch of models like the M6 but not on the M5?
