I was at the gas station last night. Off in the distance I noticed something sticking out of the garbage receptacle that looked... out of place. Upon closer inspection, it revealed a dip stick?!?
What about the time while you were working at the service station?I spent some time in college working at filling stations part time. Policy at 3 different ones for EVERY customer was: Insert the gasoline spigot and install requested amount of fuel. Ask driver to release the hood latch and check the oil (and water level if engine not real hot), inform driver of oil level, check tire pressure (add air if necessary) in all four tires, clean windshield at minimum, attempt to do all windows. Obtain payment for the gasoline purchased (sometimes it was only $1.00 - which bought ~3 gallons), and wish the driver safe travels.
I suspect it was the driver who stuck the dipstick there, left to put the fuel spigot in the tank, then forgot about it. Thankfully, since leaving those service station jobs nearly 60 years ago, I've never forgotten to reinstall the dipstick!!
Gary
Those were the good ol days for sureI spent some time in college working at filling stations part time. Policy at 3 different ones for EVERY customer was: Insert the gasoline spigot and install requested amount of fuel. Ask driver to release the hood latch and check the oil (and water level if engine not real hot), inform driver of oil level, check tire pressure (add air if necessary) in all four tires, clean windshield at minimum, attempt to do all windows. Obtain payment for the gasoline purchased (sometimes it was only $1.00 - which bought ~3 gallons), and wish the driver safe travels.
Gary
