Mich
I've read this part and have a question about it:
Keep your original springs, but remove the spacer above the front springs. Simply put the car up on jack stands, put a jack under the suspension or wheel on the side you want to remove the spacer, put a little pressure on the tire to take the weight off the 3 nuts on the strut, remove the 3 nuts, lower the wheel/suspension on that side, remove the spacer, and jack the wheel back up realigning the 3 studs into the holes. DO NOT FORGET TO SHORTEN THE 3 STUDS,OR YOU MAY DAMAGE YOUR HOOD. Another great tip is to replace your front sway bar with the larger one from a CSi.
If your rear springs sag, replace them with original springs available from the usual sources.
Your car will look great, drive great, and retain that super CS ride.
Roger
Does anybody has an picture of the spacer above the front springs? I want to lower my e9 at the front a bit, I hope this helps.
Thnx.
Roger
Thnx.
