Pertronix for 2800 CS
Seen several threads regarding conversion of 2800 CS to Pertronix. I am assuming all is OK, but noted no mention in their catalogue for application to the 2800.
http://www.pertronix.com/catalogs/pdf/ptx/2010/Pertronix2010.pdf
Also, should you go with the originial or the Ignitor II? Should you also spring for a new coil at the same time?
Identify if you have a large case vs small case distributor because the pertronix is different.
I have ignitor 1 on mine and using standard blue coil. I messed things up big time when I used there black coil....and I am afraid to try it again.
abe
I am sure Carl Nelson knows which one to use but it must be an Ignitor I but Abe is right, the distributors changed.
No personal experience, do you want to hang a big box in the engine bay? The Pertonix is subtle with no external parts and works well.
