Petri 38cm SOLD
HB Chris
Huntington Beach, CA
Bare wheel with no hub, hub cover, trim ring or button. Foam is firm with no loose areas. Back has porosity holes like most and are between 9 and 3. Front has four small scrapes or nicks between 9 and 3 as well. I rate this an 8 out 10 and is in nice condition. I found the 40 I was looking for and this is now no longer needed. Asking $400 plus shipping. Thank you.
It’s difficult to find a loose Petri hub. Repro covers are made by Wolfe on 2002FAQ. He makes all three lengths (2002, CS, CSL).
@Keshav makes CSL hubs and can offer the whole package with cover (assuming he has any left). Also @patipatina makes an adapter ring to mount a Petri in a momo hub.
I will say that a standard momo C153 is a good substitute length and width wise. A Petri cover will fit over it. If you don’t use an adapter then you would need to drill and tap the steel face. One downside is that the new momo hubs are bolt centric and not hub centric. So you need to be quite careful drilling. Good reason to go with a premade hub or adapter.
