Photos
kasbatts
Auckland, New Zealand
Hi, you have a challenge on your hands so good luck and enjoy it. If you end up having the same sort of fun as the Starlet looks to have been then you will enjoy it.
I'm tracking CSLs for the UK BMW CC and a colleague is tracking the CS/CSi, what's your VIN please, PM if you prefer not to publish. Given where you are I assume it's a RHD car.
Give my best wishes to the country I have very happy memories of visits there not so long ago.
kasbatts said:
A couple of pictures of current work being under taken (this is the last bit) when this bit finished I can honestly say this e9 is rust free!! well maybe 95% rust free?
What is the procedure for taking off the front clip?
Chicane,
I assume that you mean taking the whole front end off?
If so, and you want to keep the parts then I would suggest the following
1.. Remove front wings (drill out spot welds, cut at upper front nose cone, cut at windscreen apperture.
2.. Drill out spot welds for front nose cone.
3.. Remove bulkhead extensions (parts that go over inner wings)
4.. Drill out spot welds for inner wings.
Be warned its a long painful process
Chicane,
Chicane, Malc has summed it up spot on, and yes he's right, it's a pain in the arse job that takes lots of patience! and in the case of my left fender / guard a chisel was also employed as some previous work done by someone else made it very hard going (all sorts of bits welded together that shouldn't have been)
Hi Timt,
The BMW 3.0 CS Automatic VIN 2231518 was manufactured on November 21st, 1972 and delivered on December 22nd, 1972 to Great Britain, colour Chamonix with blue interiour, paint code 085, now living in New Zealand since about 1975, it was brought back here to NZ by the All Black Rugby player Murry Mexted
Now a manual, EFI
Hi Timt,
Now a manual, EFI
