Would anyone have a pic of the above please? I'm talking about the piece that bolts onto the regulator and onto which the window armrest looks on to.
The reason I ask is because I noticed that mine seems to have a second hole drilled right under the forward top one with matching tapping on the frame behind it for some reason. And it is on both sides. I have not seen that elsewhere and I wonder it someone drilled that for alignment purposes. I have to say it is very difficult to insert the bolt on the original top right one as it seems to drilled a bit too far back to match the captive nut behind it. And that it with all other bolts loosened and the frame pulled as far forward as possible
