This site does not allow you to upload pics directly from your computer's hard drive so you will have to upload your photos of choice into photo sharing sites such as photobucket, flickr or similiar websites. Pics all have to be jpeg images.
Photo uploading is easiest with photobucket. You can cut the IMG code of the pic and paste it onto the e9coupe site. Your photo needs to bracketed like this
for it to uploaded successfully. Click preview, if satisfied with upload then click submit. Every picture uploaded will need the same procedure. You can also do it manually. Click the IMG box, then type in the pic's full url address and click on the Close Tags.
Using flickr or other photo sharing sites maybe a little more involved. Cut the pic's url address then using this site's posting box, click on the small IMG code box, paste the pic's url address and finally click on the Close Tags letterings right below the IMG box. Check preview box to see if you've successfully uploaded your picture, if everything is fine, then click submit. You will repeat the whole process for each and every pic you want to upload.
Space a line between pics for better picture separations. for Captions above pics, type in message immediately above pictures.
Hope this helps,
Bert
72 3.0 CSi
88 M6
