Bit embarrassed to ask but I was wondering if someone might be able to check the wiring on the rear driver's side window switch (ie. the one in the back seat, not the one on the console) in their 1974 coupe. All of the wiring to that switch is present on my car however the black plastic holding the female plug together has disintegrated. As a result, i'm no longer certain which wire goes to which post on the switch. I do see that each pin on the switch has a number stamped next to to it and of course, each wire has a colour. I've tried to decipher things from the wiring diagram in the Haynes manual but it just doesn't seem to have sufficient detail. This is the last bit of electrical sorting-out that needs to be done on my coupe and i'm stumped.
