piston sizes for m30b30
budgerian
netherlands
As I was trying to find some suitable oversize pistons for my 3.0Si E3 I found a set that at first seemed suitable but wasn't.
They were for a 3.0S, which had 9.0:1 compression, whereas the 3.0Si has 9.5:1, presumably because the d-jetronic system needs the extra bump in compression.
I was about to let it go, but crossreferenced Realoem and to my surprise found out the following:
Later 3.0Si models between 73-77(L-jetronic) used the very same pistons as the 3.0S, despite still being advertised as respectively 9.5:1 and 9:0:1, both using identical headgaskets. What gives?
Should I worry much about this half percent loss in compression (although we could consider decking the block slightly to make it even less of a problem) with regard to using a fully rebuild d-jet system?
And did BMW fool us in advertising later 3.0Si as 9.5:1 when in effect they were only 9.0:1?
Interested as always in anyones thoughts on this.
If you are thinking of decking the block, may as well do it right. go to JE pistons in orange county. They made a custom set of 10:1s for my 635 for about $800 including rings and pins
