Pivot / spigot bearing : needle or ball bearing
jeme9
Australia
Current crank shaft has spacer / reducer from 32mm and then a needle bearing, although the cage and needles had separated from the needle bearing sleeve. I bought the engine so not sure when this had happened.
I am nervous about a new needle bearing also coming apart when installing gearbox.
If I was to go for ball bearing type, I would need to remove spacer / reducer from the crank.
Question has anyone had success in removing the spacer (sounds like it is harder than removing a ball bearing).
One trick I've used to remove bushes from blind recesss is to pack the recess out with grease and then hammer a rod through the bushing, the hydraulic pressure forces out the bush. Rod needs to be a tight fit on the ID of the bush of course.
Don't know if the recess is blind however, obviously this won't work if the grease has an escape route
