Plug wire - sensor pick up?
30csl
London/Herts
On the plug lead going to no 1 cylinder there is a pickup/sensor half way down the wire. It doesn't connect to the lead but slides over it and then disappears off into the loom. I'm sure someone told me I could do away with it but wanted to know what it is and where I remove it completely??
Any help would be great - thanks.
p.s. - Just about to attack the leaking oil sender at the rear of the engine - been annoying me for three - 4 years!
maybe you can post a photo of the "thing" you are mentioning
that way I can understand what you are asking for and maybe that way I can help
regards
The part in question is an inductive pickup from that spark plug wire and goes to an orange diagnostic plug located on the top of the front of the engine.
Hi Bill, is it ok to leave it off then as long as I am not using the diagnostic?
Many thanks.
Rohan
hi, bill
now I understand,
yes my mechanich told me that it was a diagnosis thing, but nobody told me never about that orange plug
but, one is in the opposite side of the other, how can you connect them ?
and where are you reading the diagnosis ?
regards
Engine Diagnostics
When E9s were new, BMW dealers had a large piece of test equipment called a Program Tester that plugged into the car through the orange plugs. It gave test data for things like ignition dwell and timing. You can see pictures and description of use if you have the factory "Blue Books" shop manuals.
I've heard of owners using some of the plug socket pins to hook up remote starter switches, but there is no practical use for the plug wire pickup that I can think of, so removing them is safe.
Thats great guys - thanks.
I may as well re install it then as it just slips over the wire.
What are the W and N plugs like deQ? I plan to order a set this week also.
Regards,
Rohan
Regards,
Rohan
hi roh
those w&n, are not-original but very good quality plugs, 7 fresh cables with their terminals (pipes on one side, and beautiful light-brown sparows in the other), convinient price, and good service
I bought a set last week personally in w&n, but of course you can do online
by the way, It was a "great" experience to arrive in Arnsberg and depart for nearly one hour with him (written appointment was needed), not only he had my parts prepared for packaging, but he gave me a lot of advises and help with my questions and doubts about my car, I recomend the journey if possible
regards
regards
hi roh
regards
Did you meet Mr. W or Mr. N?
Right, the plug is a tool even if you don't have the BMW tester. You can test (jump) the starter at pin 7, test alt output at 8. I haven't tried to do anything else.
Jon
checked the diagram: the inductive pick-up on #1 is pin 4,5,6 and the pick-up on the coil is pin 2
hi arde
mit herr albrecht, genau
I didn´t had the pleasure of meeting herr alexander this time
do you have a personal experience on visiting them ?
regards
Never been there, but I visit Carl Nelson whenever I am in San Diego. Lining up a trip in a couple of weeks. I am sure it is a different yet similar experience.
hi
unfortunately I don´t know who Mr. nelson is, but I guess he is an homonimum of mr. walloth, does he run a spare parts bussiness ?
good luck with that trip
hi
Stopped by La Jolla on Friday to do the E36 oil change, there was a flared E9 of same color as our E36, and we got to breathe around other vintage cars. James Bond wasn't around so my wife sat inside his car, she said it wasn't comfortable at all, so I pass on that one. Phew...
