I am planning on changing the rear trailing arm and sway bar bushings and the subframe mounts as part of my restoration. I usually use BMW/Lemforder etc for this but the prices are similar to black poly parts from Ireland Engineering which are also easier to put in. I also have that little hairline crack behind the differential that runs through the hole for the gas line which I reinforced.
Main concern is stiffness when combined with Bilsteins in ride but also rigidity which will translate through subframe mounts . Comments appreciated.
