any help would be appreciated! also does anyone have a sound system, with headunit? are there any small enough to fit in the tiny space of the stock one, or is a cutting in need
Ireland engineering or Korman do a urethane donut that goes half way down the shaft but other than that I cant think of any other bushings in the steering linkage. Is that the one you mean - a circle with four bolt holes?
thanks, yes i ment the frame rails. and about the steering, i want to replace all rubber parts. and screws and bolts i think im just gunna look on realoem.
i think i read somewhere that someone used an e28 steering poump, and it had much more power, can i use that pump on the 3.5 in the cs and connect the pump to the exxisting cs hydrolic srteering box
