Putting Hand Brake back on Rear Axle
scanty
Bay Area, CA
Clearly I did something wrong while putting this E brake back on but I'm not sure what. As it stands the E brake on the rear axle right hand side is so wide I can't slide the rotor over the top of it. I took some pictures to try and show you what I mean. Any guidance as to what is causing this would be greatly appreciated.
The metal silver clamp esque looking thing is what i believe is intended to expand and push the shoe in and out. It turns out the pieces below (Picture 3) fell off when I took it out. And I have no idea how to put them back in. (See attached)
The yellowish thing in between the two black pieces appears to be pushing the brake shoe further out then intended. Do I need to do something to it? Or by chance did I put the shoe on incorrectly?
Problem Solved!
Thanks for the Picture. Turns out that small metal pin is used as a sort of pivot joint, if you will, for the rest of that metal piece. I put it back in a it worked. Also the star adjuster at the top needed to be brought a few clicks left inorder for the top space to not be so wide.
