Question for the Zenith gurus...
Honolulu
Honolulu Hawaii
Is it correct that the secondary butterfly is not closed at idle? If I close the secondary at idle with my hand, the idle drops. I suspect my carbs are quite a ways out of whack, and this may be part of it and a good place to start.
TIA
Yes and there is a set screw on the side of the carb (out of the way-on the underside of the linkage) to adjust this, just open enough to keep it from binding, tiny amount. Then use mixture and butterfly screws for the rest.
Secondary butterfly should be as closed as it can be without sticking in the bore
Right then, thank you gents. I know the adjustment, just a matter of getting my big fat fingers around the adjustment.
