Tierfreund
Hi all
I need help with an issue thats been haunting me. I´ve converted my 71 3.0S E3 back from tripple webers to the stock zenith carbs. Now on the 71 euro E3 that means the earlier simple carbs without TN-starter and a simple distributor with vac advance only. No emissions control equipment on either.
Now the trouble I´m having is figuring out where to connect the vac advance.
The carbs have three vacuum hose connectors each. One at the engine intake side, one at the side that points to the brake booster and one that point forward in the direction of the radiator.
I know that the connections at the brake booster side get joined from both carbs via a y-piece and then connected to the air filter housing to join the engine breather pipe.
What I don´t know is weather the vac advance gets connected to one of the connections pointing to the engine, to one of the connections pointing to the radiator or to both carbs, again connected via a y-piece (and if, which connector...)
The setup would probably be found in the US on the 2800CS and / or very early 3.0CS (before legislation added emissions control equipment and later the TN-starter).
Any suggestions or pictures? I´ve been scratching my head for quite a while now and the blue books only explain the connectors on the later carbs with TN-starter which has quite a different throttle body.
Any help is appreciated.
