Any recommendations on tyre size for the old csl running on 14 inch Alpinas ? I think, according to the unused original spare tyre it was fitted with 195x70 x14 inch tyres when new and its currently on 205/70 x14 tyres that have hardened over winter and started to crack.
Its its first run this year, got it off the blocks, checked the oil, water and all the fluids and all was fine. Decided to give it a quick oil change and a new battery as the last one was on the way out and it started first time. Done around 50 miles in it today with out problem and its so good to drive after the daily slush mobile.
Going away in it for a week end and need 4 new tyres and really need to get them before I go and the only ones I can get local are 205/60 x14 would they be OK ? If you go from 195x70 to 205`s the aspect ratio should be drop to 65 ? if that's the case the 205x70`s have to higher side wall and the 205x60`s have to lower aspect ratio. What should I go for ?
Marc
Marc
