Stick with Freon
If your car has been sitting without the a/c working for a long time, you first need to ascertain the status of the system. A/c systems do not naturally leak, so if it has no freon in it, it is leaking, and the leak will have to be detected and fixed regardless of whether you stay with freon or switch to R134a.
If the system has been sitting but closed (ie, the compressor is still there and all the hoses are intact), you may be able to get away with finding and repairing the leak, replacing the receiver/dryer (always necessary when opening up the system), and recharging it. If you're lucky, the leak is trivial, such as in a hose or at a fitting. More likely it's at the compressor seal or in the condenser in front of the radiator. If you're unlucky, it's inside the evaporator console, which means the console needs to come out, which is big league suckage.
If the system has been sitting open (ie, compressor missing and hoses disconnected), you must first flush the system (the hoses, evaporator, and condenser) with a/c flush or mineral spirits to remove contaminants.
Once you have a leak-free system, THEN AND ONLY THEN can you address the issue of changing to R134a. When R134a conversions first started, the conventional wisdom was that the compressor to be changed because the two systems used incompatible oils (mineral oil for freon, PAG oil for R134). However, over time, a less invasive technique involving simply draining the oil oil from the compressor and using Ester oil which is compatible with both refrigerants.
All that having been said, Freon is still widely available. If you live in SoCal, I'm sure there are shops that work with it (unlike here in Boston where, since it isn't that hot, there are very few specialty a/c shops).
Long story short, if you have a basically intact system and you want a cold car, stick with Freon. The concern over the price per can isn't worth going through the conversion.
If you are doing a from-scratch installation or resurrecting an open system and may need to change several components, then R134a may be worth looking at.
I did a from-scratch installation in my CSi about 15 years ago and went with R134a. It works ok, but again it doesn't get stinking hot here in Boston. When I drive the car in 95 degree weather, it gets overwhelmed and I wish I'd stayed with Freon.
--Rob
