Radiator dimensions
Mine measures 4 cm thick x 48.5 cm tall x ~58 cm wide (the cooling fin part, not including the side tanks).
~66 cm tank outside to outside - at top and at bottom. Note, that the right side is wider at the bottom and the left side wider at the top - so the 66 dimension is offset between top and bottom.
Outside of top brackets is ~68 cm.
