Radiator removal
pmansson
switzerland and sweden
Can this be done with the bonnet/hood in place ???
When I look at it, it seems hard to see how it can be exchanged with the bonnet open but in place.
My thin one is damaged and I want to install the slightly thicker one, for cars with AC as W&N defines it.
Thanks,
Peder
Thanks,
Peder
no problem peder,
yes it can be done with the hood in place, but if your installation is original you must remove the fan at least
i have the wn ac radiator, no issues so far
Recently replaced mine with a triple core. Hood can stay on. Its a bit heavy and needs to be tilted a bit so its ackward, two people would be better but I was able to do it by myself. I replaced all of my hoses, fan, clutch and water pump at the same time. It just made sense to do it all and not have to worry about it.
I actually supported the hood then tied a thin nylon rope to each side of the radiator and ran the ropes thru the hood latches, two people lowering it crane-like. Lots of control.
