K kys911t Well-Known Member Site Donor Messages 347 Reaction score 73 Location So Cal Jul 29, 2011 #1 What would be an appropriate Radio Antenna for a 74?
Stevehose Well-Known Member Site Donor $$ Messages 13,764 Reaction score 6,737 Location Sarasota, FL Jul 29, 2011 #2 Option 2 or 3 (not # 1 - red tip) depending if you want manual or auto. http://www.beckerautosound.com/hirschmann antenna/hirschmann_1951-1972_porsche.html Hirschmann 6000 is the base model auto, there were variations depending on year and car brand.
Stan Well-Known Member Site Donor $$ Messages 7,409 Reaction score 1,834 Location Newmarket, New Hampshire Jul 29, 2011 #3 Or close the hole and go with mast-less antenna
Stefan Well-Known Member Messages 529 Reaction score 10 Location Sweden Jul 29, 2011 #4 Option 2 or 3. Depends also if your radio got an antenna signal for option 3. According to me an 1974 E9 would go for option 3. Close the hole with an defect antenna if you're going for the modern mast-less antenna
Stevehose Well-Known Member Site Donor $$ Messages 13,764 Reaction score 6,737 Location Sarasota, FL Jul 30, 2011 #5 Mine came with a switched power antenna, I have to flip a switch to raise and lower the antenna, switched with the radio power on/off came later. Stefan said: Option 2 or 3. Depends also if your radio got an antenna signal for option 3. According to me an 1974 E9 would go for option 3. Close the hole with an defect antenna if you're going for the modern mast-less antenna Click to expand...
sfdon Well-Known Member Site Donor $ Site Donor $$ Messages 10,008 Reaction score 6,831 Location sfbay area Jul 30, 2011 #6 Bav auto had the oem antenna on closeout for 10 bucks last month.
