Rear Brake rattle spring.
m5bb
Peachtree Corners, GA
Does anyone know if the rear rattle spring set 34211150557 for a 630 will fit a 72 coupe rear calipers? This is 2 rattle springs and 4 pins to hold pads.
That is the part number shown for a coupe on the Penske site I use to look up numbers. I do not buy from them.
But when cross referenced it shows up on Bav Auto as a set for a 630 or 633.
Gary,
When you look up a part on a Penske as I also do, in the upper left it says Change Vehicle. If you click here and the paste in the part number and hit Search you get this:
http://www.penskeparts.com/DiagramsByPartNumber.aspx?parts=34211150557
It fits e3, e9 and e24. It shows all applications for every part. I then paste that into Tomkinson BMW and get the best price.
Chris
Hey Chris,
Thanks for the tip on the Penske site.
I usually go to Real OEM and do the same thing.
Yes, early model 6 series and E3 Sedans.
Guess I was kind of hoping for some mystery car that used this part and it was readily available. Yea, right! It's a coupe full of unobtainium.
Thanks,
Gary
QUOTE=HB Chris;101969]Gary,
Chris[/QUOTE]
I don't waste my time on RealOEM anymore, their prices are way out of date and the Penske site has the exploded diagrams instantly.
Chris,
the penske site doesn't always have everything on it. i was looking for a few items - it wasn't on penske ... it was on real oem and it was on tomkinson. of course the inverse is also true.
scott
Tomkinson doesn't let you search for older models like Penske does so I use Penske first. I occasionally use RealOEM if I can't find it elsewhere or use the parts books.
Not going to happen with World Pack or any others so just ordered from the dealer.
4 sets in US.
Be here Tuesday.
