Rear Bumper Trim Fastener
NewSixCoupe
Northeast
Thought I'd reach out and see if anyone has this rubber trim fastener from a '74 US-spec coupe. Fastener by itself would be great, washer and nut an added bonus! Thanks.
Look on page 51/5 or 51/10 for your year and model coupe on http://www.realoem.com.
The clip and washer should be available from your dealer or Maximillian.
Item #14, Clip P/N 51111838076 $1.98.
Item #6, Flat washer, P/N 07119931044 $0.58.
Item #7, Hex nut, M6, P/N 51111835624 NLA.
The nut is a common size, so your delaer should be able to match that.
I already ordered these parts from the dealer and what I got was totally different, more like a spring clip than a threaded bolt. The washer is also different, and the nut, as you indicated, is NLA. Thanks.
T-bolts
The picture you posted looks very similar to the fasteners used to hold the rubber trim on the rear bumper of my 1973 tii. Here's the parts numbers I used to order them for my tii:
Fastener (T-bolt) 51111815611
M6 Nut 51111835624
Washer 07119931044
Maximillian shows all three parts numbers as available. The M6 nuts and washers you can find at any hardware store (they just might not be yellow zinc plated). You might get stainless ones instead since they do tend to rust back there on the bumper.
Good luck,
--John
