rear lights restoration
joop
Belgium
Hi to All,
Does anyone know if it is possible to divide the red, orange and withe plastic from the chrome parts of the rear lights. Most lights you find have good plastic parts, but the chrome needs to be redone, or the chrome is good, but the plastic is broken! :roll:
thanks in advance
Joseph
if you take a pliers and catch the plastic lip on the inside which holds the lenses in and break it off the lenses will come out. you can then glue them back in. Worked for me.
I did this successfully as well...
I used a Dremel with cutter blade and sliced off the plastic lip around each lense allowing them to pop right out.
I then epoxy'ed nice lenses in good frames.
Turned out fine...
