Muffler options continued
Depending on your budget and objective here a little more to consider:
1) Although 3.0 cs mufflers are scarce or pricey, 2800 is not. I've seen them advertised for $80-100. The catch here is that the inlet and outlet is slightly smaller than a 3.0. ( Approx. 2,1/16" vs. 2,1/4".) So if you're stock, all is well. But, It seems logical that it's basically a welded can and new larger inlets and outlets are just a grind and weld away. Save the flange for the tailpipe and you can just bolt on a new one.
2) Although Flowmaster's 18" is the normal replacement, there are manufacturers other than Flowmasters who make the same muffler for $20 (aluminized steel) vs. $100 (ss). Still need to modify and weld. But heh, that future 3.5 with 2, 1/2 dia. is looking pretty good. If you're really worried about the noise- Flowmaster has longer mufflers in a "hush" series up to 32" with better baffles.
My car has a monza exhaust from many years ago with cast dual tips. ( BSS- before stainless steel) It doesn't have the center muffler and it seems pretty tame to me. No neighbors with shotguns out... and in my area they're everywhere!
