Rear Quarter Window Leading Edge Rubber
kys911t
So Cal
I just replaced the front leading edge rubber of the rear quarter windows. The existing ends were so torn up, I do not know how they should be cut. Can someone post the correct cut at the top and at the bottom. The top fits into the top rail and the bottom makes its way into the rear quarter of the car and can catch if not watched. In addition will they compress a bit after time? I noticed that now one of my front window will not move up all of the way as it compresses against the rubber. Tried to adjust the jambs but now luck. The fit is good, it seems that the compression is just a bit too much.
