Bwana
The saga continues.....
I took the rear shock out, no big deal there. Simply take the covers off the fenders in the trunk and unbolt the shock from both ends. I had spported the axle first though because I don't know if the shock limits the downward travel of the suspension.
However, I found this after I removed the shock and load plates
From above
From below
Somehow I don't think it should look like this. I'm suprised a bit though because it looks like the metal "broke" away as opposed to rusting thru. So can this be repaired in place without taking apart the whole rear section of the car? Should I put the old stuff back in or continue with the new springs and shocks and let the repair shop take them back out? I've not checked the other side yet, stay tuned.
Also, do I just let off on the jack to drop the suspension and replace the spring?
From above
From below
