Rear spring pad removal
decoupe
(deceased)
Alberta, Canada
I need to replace the lower spring pad on the passenger rear - do I need to remove the half shaft first or can I just undo the shock at the top and carefully lower the swing arm until I can remove the pad?
I'm hoping that lowering springs are short enough to avoid the compressors but I have a set in case.
Thanks for the info.
