So, I purchased this subframe in the hopes of dialing in a little bit of negative camber using the eccentric bolt and washer that you can see inserted here:
When I looked at this subframe side by side with the one I just removed from my car, however, it appears that the outer mounting points for the trailing arms are higher on my old subframe than they are on my new subframe. (I am unsure where the original inner mounting points on the new subframe may have been because they have been modified to accommodate the camber adjustment). This change in the outer mounting point would appear to cut against what I am trying to accomplish.
Here is a picture of my existing subframe (and yes Peter -- that is yet another TX mud wasp nest on the top of my differential. I thought I had gotten rid of all of them):
Short of installing the new subframe and seeing what my rear suspension geometry may look like, does anyone have any suggestions?
