Yep, that is how it goes.
Even if you puit it in backwards, however, it just means you'll have to put the switch in upside down, or switch how the wires are connected to the switch. All it does is effect a voltage difference over the motor, making it work. The way the wires are connected determines the direction of that difference, and ergo which direction the motor will move the window, up or down.
