acat2002
I have finally freed up enough garage space to start working on some "quirks" that bothered me all summer. I'm going to go through the electric system over this winter making sure harneses are okay, insulation is good, grounds are not corroded etc. Of course my coupe has all of the normal electric issues (windows, wiper motor etc.). I'm starting with the inoperable rear windows.
I have the shop manual (Blue Books) showing the procedure for removing the rear window motors, but the procedure includes lowering the windows to access a small screw on the inside (Sec. 51, Pg. 37/2 for those with the books).
My trouble is that the windows are both stuck in the up position. Is there a method of either manually lowering the rear windows, or "jumping" the rear window motors to life? I find it odd that both motors won't work at all, so it's probably an electrical issue in the harness or ground/fuse problem. Regardless, I still need to access the motors and in order to get the panel off will need to somehow crank the windows down.
Anyone here run into this? Tips? Pitfalls?
thanks,
Aynsley
thanks,
Aynsley
