Somehow during the reassembly of my wiring, the rear window switches now operate opposite from the fronts. In other words when I press the switch towards the back of the car the rear windows go up while same operation on the front switch makes front windows go down.
Since my car is a 74, the wires are attached to a female receptacle into which the switches hook up. I did not remove any of the wires from the receptacle in the center console so I have a feeling that is not where the problem is. However the switch in the rear armrest did get disconnected from their receptacle on the left side. So I wonder if reconnecting them incorrectly created this issue. Does anyone know which two wires need to be swapped to reverse the direction up or down?
The wiring diagram is difficult to follow bc the pole numbers on it are different than on the actual switches.
Thank you
Thank you
