Rear window weatherstrip
inovermyhead
Sydney
Anyone know if the weatherstrip mounted in the channel that the rear side window closes into, is the same as used on the doors?
It was a real snug fit, a little tricky getting it out, is there a tip for installing?
Cheers. John
Cheers. John
assuming that i understand well which part is that one you mentioned, yes, it is the same,
tip, place the clips evenly in the length of the new part, use your thumb to install it inside the channel
dequincey did it and documented it with pics, search for the thread about rear windows
