Single green wire to ballast base from fuse #6. When hooked to the ballast resistor with the key in the running position, , the resistor turns cheery red. Multimeter to the green wire gives me 12V and 1.0 ohms regardless of ohm setting. Ballast itself has 1.2 ohms across it. I could not get a read on the wire's current. I will add that this issue existed when I bought the car, then disappeared. My resto is done and while starting it today, the issue appeared again. Interestingly, it does start despite this.
Wiring diagram has this wire as a straight shot from the fuse box to the ballast other than running through a diagnostic port. I can run a new wire from fuse 6 but really want to figure out what is going on here. Any help appreciated.
