trim redo
The gutter trim is relatively inexpensive, and was available as of about a year ago. Its really too flimsy to remove, strip, and polish without more patience that I have for polishing pasta.
The belt trim is much more substantial (solid) but not any fun to remove(I was told, as I didn't do it). I did strip the old anodizing, and then had them polished. It was recommended to me to POR 15, or other, the t-nuts (new ones) where they touch the aluminum, as the steel will react with the aluminum. I had to cut some of the old ones out with a Dremel tool that were locked intimately with the channel. I went through the debate of re-anodize, top coat, or carnuba wax. Since my car will be garaged, and will not see precipt (if I can help it), I went with the wax. I also did the backside before re-installing. That way, if they need any polishing down the road, I'll just mask them, Mothers aluminum polish, and re-wax.
Some of the window trim is chromed steel. Mine is tired, and I'm not sure,but doubt availability new. Anyone know? Its one of my final (no such word in coupe-dom) cosmetic to do's. I do some work in Thailand, and may try to take a few pieces over on my next trip, as I hear that they do some great re-chroming/and restoration work on cars from the UK. Gotta be cheaper than here as well. Film at eleven.
Dave V. in NC
