Are you switching to fuel injection and you want to know the appropriate fuel pump, or are you converting the mechanical fuel pump to an electric fuel pump for the carbs? The two are very different units.
If it is the former, just about any M30 Motronic fuel pump will work. I've seen the same Bosch unit used in just about every european car from the 80s until the early 90s.
Try a MSD 2225 fuel pump from either Jeg's or Summit About $104, Summit also lists one under the Summit brand that I believe is the same pump for about $85. Either one should be good, they are good up to the 500hp range. Good luck, Leroy
