Honolulu
I have the clock out my my not-so-gently hands, and the fusible link, the famous weak spot, has parted company. It will tick and run if I put gentle pressure on the main wheel (surely there's a proper name for it in the business) but when it winds down, without power to the little solenoid, it won't rewind by itself. This clock hasn't worked since I got the car in the mid-80s. I'm on a mission...
The plastic shell of the clock clearly states that repair should only use solder with a melting point of 120 degrees C which equals 248 degrees F.
Has anyone got a pinhead-sized amount of this stuff that could be used to put the fusible link back together? Not surprisingly, I've called 19 different electronics shops and visited one, none of them will either a) do solder work or b) have anything other than "normal" tin-antimony or tin-lead solder. I'm not in the market for ROHS compliance, but that may be moot since I think no lead solder will have a melting point that low.
I have read of good results from North Hollywood Speedo, and there are other otufits that have been used by members of this group. But.... it's only a pin-head sized project. I've arc-welded, mig-welded, heliarced, soldered and brazed with variable results and (I think) would readily get this done if the correct solder were at hand. Looking online the correct stuff may be an indium alloy paste with some flux mixed in. "Indalloy 1" and "Indalloy 18" appear to meet the spec.
SO. Anyone got a teeny bit to share? Beer on me, here, if you happen to...
