It's that time, what do people recommend - I see an OEM-style one on ebay which is fine, are there stainless options as well? At quick glance did not find any when searching. Just need from the manifold back.
Go to RealOEM and the first illustration in the exhaust system will show you the difference, the RHD down pipe is connected to one flange .I'm speaking with someone now in the UK who can fabricate them but they don't have the LHD downpipes (the two bent ones that connect from the manifold) in their shop - does anyone know if there is a difference between the LHD and RHD downpipes?
Just had a look at my parts books and it would seem that LHD down pipes are common to E3 and E9. As you are making enquiries in U.K. I see that Jaymic are listing LHD stainless steel down pipesah, good call, thanks
That's what I did. I kept the stock pipe diameter and exhaust exit location at passenger rear, but I only have a 12" silencer and no muffler. It's a little loud but I wanted it that way.Take it to a muffler shop that does custom work. They can fab anything much cheaper than stock or OEM. Its mostly just welding pipe.
I have a muffler I will not be using. Not original but fits the car.
I am doing away with the 90 degree bends and going straight back out the middle of rear. Shop will cut and sculpt the sheet mettle.
