replacing rear seat
inmantua1
ok they came out easy. But i cannot get them back in. I understand that the slit in the fiberglass needs to slide under the L shaped metal but i cannot get it far back enough to slide under. anyone have any suggestions?
easy on mine
To remove, tip forward and lift out. To install, set the front lower edge in place and tilt back. Too simple.
If you are having problems, maybe the seat belt or something is in the way? Dunno what fiberglass you are referring to - maybe not stock, in which case you're on your own.
