restoration of headrest for scheel seat - bnn style
deQuincey
Quousque tandem...?
small project inside,
some guy, you know him, right ? was so kind to offer a bnn style headrest that belonged to a scheel 100 seat
i have my scheel 100 equipped with conventional headrests but this looked interesting so i gave a try as it was clear it was not going to be a plug and play (this actually made things more exciting)
after my extensive resto of a scheel 100 seat ( https://e9coupe.com/forum/threads/a-scheel-tale.22688/ ) (thank you phbckt for deleting the pics) i was prepared and with enough knowledge and expertise to accomplish this challenge
so what´s next ?
so a quick overview,
fabric was not very happy, it was disintegrating in form of a persistent black dust
structure was not chromed anymore
foam was,...eeerrrr, well 40 Y.O., right !
so what to do ?
try to make a new foam,....
first problem, proper material should be very high density 70/80 automotive quality, difficult to find
but there are always places,...
Tell us the rest of the story. Knowing you, you have made a headrest better than it originally was.
Also it gave you something to do in the winter (do u have winter weather ;)) to keep you gainfully employed!
yeah, but how do you cut foam when shape is 3D ?
this did not worked well
i made a completesetup including a 12 volts 8 amp source and an electronic regulator, ending up with a hot wire able to cut expanded polyester, but not foam,...scheisse !
and a ham knife worked no good:
so finally i decided to make the foam stable by vacuum plus CHCL and some impact glue to repair broken pieces, previously i removed the frame by a surgical cut (with the ham knife)
DeQ - upholsterers use an electric bread knife to cut foam - might be worth checking out next time you've got a foam project
i tried that too, problem is density, the foam for a headrest is very heavy, dense and (latex addition makes it very sticky
ham knife is sharp like a razor´s blade, was good for seat foam
it is like a glove but you must finish by hand once the insert is inside
i dedicated some time to think how to sew these two ends together while keeping the tension and making it uniformly
the answer is in this photo, smart, isn´t it ?
as excellent as always deQ ... so where did you get the scheel fabric from - Gerrit? i want to get a piece about 1.5 / 2m long (full width) to do the insets on my scheel sport seats
by the way, we used to make architectural mass models with the hot wire machine. we used a rigid foam ... with practice you could cut a sphere. soft foam for upholstery? might be a bit difficult.
