Rocker arms - valve closure
30csl
London/Herts
Hi guys,
If i want to get the valves in the head to all close - how can i move the rockers over so that they are not in contact with them? Is there a circlip holding them in place that i can remove?
Thanks,
Rohan
Yes, there are. You might also try loosening the rocker arm eccentric adjusters.
It's likely you still have to turn the cam and remove the head.
Not sure what you're doing- checking for wear? checking for valve sealing, tip wear, etc.
