nealf
Hello all..If anyone was following my plight to install an OEM distributor last week and the frustration I had, it is finally over as I found TDC by pulling the valve cover and lining up the cam/rockers. The car started immediately and I was real happy. I did this whole distributor thing because someone had installed a Roto Faze one on my car and I thought the contact button in the motorcraft cap was failing. The result was backfiring, non idiling, and general rough running.
Much to my surprise, the car is running the exact same way with the OEM bosch '002' distributor. I had thought it could have been a weber carb problem but many told me it was an ignition problem. WHere do I go from here? The timing is pretty correct, wires all look good as does cap, points, not sure about condensor though. Also the coil is not a Bosch unit. Would that make a difference?
Thanks.
nf
'70 2800CS
'73 2002
Thanks.
nf
'70 2800CS
'73 2002
