Searching for Late 1971 Cylinder Head
Dowst
Casting PN should end in 199, I believe. Looked through a cache of about 20 heads, hardly a surprise that I came up short on this particular vintage.
Understood later heads are more robust, but seeking a casting that is correct to the chassis.
Regards,
Alastair Dowst
NH
(603) 439 1061
I have one.
Thanks, can you confirm the date code cast into the side of the head?
BearMW
Thank you for your reply and effort to post pictures. I believe this might not be the solution I am seeking as I need a head with a ‘71 casting. ‘72 is close, but not correct for the application. Looks like yours was manufactured first month of ‘72.
Thanks again!
